> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/gateway/knowledge-base/knowledge-base-articles/devolutions-gateway-recording-path.md).
# Devolutions Gateway recording path
This topic serves as a reference for general information on Devolutions Gateway recording.
The recording format is WebM and the file size is around 15 kb/s, depending on compression.
The recording path can be set in the Devolutions Server Console only.
![](https://cdnweb.devolutions.net/docs/DVLSCONSOLE4010_2024_2.png)
Here are some important considerations:
* If the new path is set to a network location, like a shared folder or a UNC path, be aware that this may impact network traffic, both incoming and outgoing.
* Confirm that the account operating the gateway service has the necessary permissions to access both the gateway files and the file share.
#### Devolutions Gateway recording destination path (Linux manual configuration)
1. Open the `gateway.json` file located in the Gateway installation folder using a text editor.
2. Add the following line to the JSON file: `"RecordingPath": "<destination folder>",`
3. Be sure to use double backslashes, as in the following example:`"RecordingPath": "C:\\Recordings",`
4. Restart the Devolutions Gateway service.
GET https://docs.devolutions.net/gateway/knowledge-base/knowledge-base-articles/devolutions-gateway-recording-path.md?ask=<question>&goal=<endgoal>
