Devolutions Gateway recording path
This topic serves as a reference for general information on Devolutions Gateway recording.
The recording path can be set in the Devolutions Server Console only.
Here are some important considerations:
If the new path is set to a network location, like a shared folder or a UNC path, be aware that this may impact network traffic, both incoming and outgoing.
Confirm that the account operating the gateway service has the necessary permissions to access both the gateway files and the file share.
Devolutions Gateway recording destination path (Linux manual configuration)
Open the
gateway.jsonfile located in the Gateway installation folder using a text editor.Add the following line to the JSON file:
"RecordingPath": "<destination folder>",Be sure to use double backslashes, as in the following example:
"RecordingPath": "C:\\Recordings",Restart the Devolutions Gateway service.
Last updated
Was this helpful?
