Ngrok tunnel with Devolutions Gateway
Devolutions Gateway can operate behind Ngrok to add an additional layer of protection to an internal Devolutions Gateway installation or to allow an outbound tunnel when changing a firewall configuration is unavailable. Using Devolutions Gateway behind Ngrok is available for both Devolutions Server and Devolutions Cloud. The Ngrok tunnel can be added to an already existing gateway by changing some settings in the gateway.json file.
Configure Ngrok
Log into the Ngrok dashboard.
Go to the Domains section which is under Cloud Edge.
Click New Domain.
Input the domain details and click Continue.
Under Cloud Edge, select the TCP Addresses section and then click the New TCP Address button.
Modify the information if needed and click Continue.
Go to Getting Started — Your Authtoken and click the Copy button.
Retrieve the provisioning key
Log into the Devolutions Server or Devolutions Cloud instance as a user with access to the Devolutions Gateway configuration.
Go to Administration — Devolutions Gateway.
Click the More button and select Download public key.
Install Devolutions Gateway with Ngrok
Open a connection to the server hosting Devolutions Gateway and download the installer.
Run the installer.
Click Next.
Once the desired installation path is selected, click the Next button.
Check the Enable access over the internet using Ngrok option and click Next.
Enter the Ngrok settings and click Next.
Specify the path to the previously retrieved public key from Devolutions Server or Devolutions Cloud and click Next.
Click Next and then click Install.
Configure Devolutions Server
Log into a Devolutions Server instance as a user with access to the Devolutions Gateway configuration.
Click the Add (+) button and choose Gateway.
Enter the previously retrieved details from Ngrok used to configure Devolutions Gateway.
Click Save.
Click the ellipsis (More) button next to the newly configured gateway and select Publish revocation list.
If the Publish Gateway configuration option is available, it should be done before Publish revocation list.
Configure Devolutions Cloud
Log into a Devolutions Cloud instance as a user with access to the Devolutions Gateway configuration.
Click the Add (+) button.
Go through any combination of Vaults, Groups or Users tabs to decide how the licenses will be distributed.
Click Add.
Click the ellipsis (More) button next to the newly configured gateway and select Publish Gateway configuration.
Last updated
Was this helpful?
