> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/gateway/knowledge-base/how-to-articles/launch-an-ssh-session-in-a-web-client.md).
# Launch an SSH session in a web client
Launch SSH terminal sessions from a browser through the Devolutions Server or Cloud web interface using Devolutions Gateway.
Launch SSH session directly from your favorite web browser via the Devolutions Server or Devolutions Cloud web interface.
### Requirements
To use this feature, certain requirements must be met, namely:
* Windows 10 or 11.
* [Devolutions Gateway](https://docs.devolutions.net/gateway/getting-started/devolutions-server/devolutions-gateway-configuration-with-devolutions-server.md) version 2023.1 or later.
* [Devolutions Server](https://docs.devolutions.net/server/getting-started/installation/devolutions-server-upgrade) version 2023.1 or later.
* An [SSH terminal session](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/entry-settings/ssh-terminal) entry with a Devolutions Gateway VPN type configured must be created.
* A Remote Desktop Manager or Devolutions Launcher license must be assigned to the user launching the session.
### Supported session entries
Other session types can be launched via the Devolutions Server web interface:
* Active Directory
* Apple Remote Desktop (ARD)
* PowerShell (remote)
* [RDP (Microsoft Remote Desktop)](https://docs.devolutions.net/gateway/knowledge-base/how-to-articles/launch-an-rdp-session-in-a-web-client.md)
* SSH terminal
* Telnet
* VNC
### SSH terminal session configuration
Follow the steps below to properly configure your SSH terminal session to launch it in a browser:
The steps below assume that you already have an SSH terminal session entry. If you have not yet created it and want to learn how, see [Create entries manually](https://docs.devolutions.net/server/web-interface/vaults/entries/create-entries-manually).
1. In the Devolutions Server web interface, go to the ***Properties...*** of your SSH terminal entry.
2. In the ***VPN/Tunnel/Gateway*** section, select ***Devolutions Gateway*** in the ***VPN type*** drop-down list.
3. In the ***Connect*** drop-down menu, select ***Always connect***.
4. Under ***Settings***, select the Gateway to use for this connection, then click on ***Check health*** to make sure the Gateway is functional. Its version must be 2023.1 or later for this to work. Click on ***Update*** to save your changes.
5. Once all the conditions are met, you can press the ***Open in web client*** button.
### See also
* [Launch an RDP session in a web client](https://docs.devolutions.net/gateway/knowledge-base/how-to-articles/launch-an-rdp-session-in-a-web-client.md)
* [SSH terminal entry options](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/entry-settings/ssh-terminal)
GET https://docs.devolutions.net/gateway/knowledge-base/how-to-articles/launch-an-ssh-session-in-a-web-client.md?ask=<question>&goal=<user_goal>
